03-02-2012 06:18 AM - edited 03-02-2012 06:19 AM
03-05-2012 08:20 AM
Mr Santos,
Are-you asking how to wire a LED to the WSN-3202 ? Relying on the manual, you have to wire it to pins 9 and 10 for instance. Be sure that the module is configured as you wish (in the project explorer, right-click on the module and select properties).
Pay attention to the tension, the output is 12V.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
03-09-2012 06:07 AM
Good morning,
for programming in LabView plates WSN, I need to have LabVIEW WirelessSensor Network Module Pioneer?
For example, I need to have input and output, can do the way is down?
regards,
Hugo
03-09-2012 07:49 AM
If you want to programm WSN nodes, you need the Module NI LabVIEW Wireless Sensor Network (WSN) Pioneer. If you just want to read data from nodes, without programming them, you can just install the WSN drivers.
I don't understand your second question. If you need help for starting with WSN, please look here.
03-09-2012 08:02 AM
Thanks for reply.
I want read and write with node WSN 3202. I need de LabVIEW Wireless Sensor Network Module Pioneer?
Hugo
03-09-2012 08:14 AM
If you just want to do that, you don't need the module.
03-09-2012 08:33 AM
So to get in an output voltage value, I'll have to do?
Hugo
03-09-2012 08:49 AM
Can you tell me exactly what you need ?
If you want to set an ouput voltage value, it's impossible. The only outputs avaliable on this node are digital outputs. When you set it to True, the output voltage is 12V.
Is that what you need ?
03-09-2012 09:03 AM
I needed a hardware trigger voltage of 24Vdc, it is possible?
Hugo
03-09-2012 09:16 AM
No, it's impossible. Moreover, do not think of using two outputs in series connection. Grounds are internally linked so if you do that, you will do a short.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
