Wireless Sensor Networks
Reply
Using outputs in WSN-3202
[ Edited ]
Good morning,
I have a doubt. You are aware that the sensor WSN-3202 has 4 analog inputs and4 digital outputsa doubt arises in respect of this sensor outputs.
For example, for connecting a LED (6V) to one of the outputs of the sensor, I have to do?
Hugo Santos
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 1 of 18 (3,474 Views)
Reply
Re : Using outputs in WSN-3202
Mr Santos,
Are-you asking how to wire a LED to the WSN-3202 ? Relying on the manual, you have to wire it to pins 9 and 10 for instance. Be sure that the module is configured as you wish (in the project explorer, right-click on the module and select properties).
Pay attention to the tension, the output is 12V.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
Message 2 of 18 (3,463 Views)
Reply
Good morning,
for programming in LabView plates WSN, I need to have LabVIEW WirelessSensor Network Module Pioneer?
For example, I need to have input and output, can do the way is down?
regards,
Hugo
Hugo Santos
Message 3 of 18 (3,447 Views)
Reply
If you want to programm WSN nodes, you need the Module NI LabVIEW Wireless Sensor Network (WSN) Pioneer. If you just want to read data from nodes, without programming them, you can just install the WSN drivers.
I don't understand your second question. If you need help for starting with WSN, please look here.
Message 4 of 18 (3,441 Views)
Reply
Thanks for reply.
I want read and write with node WSN 3202. I need de LabVIEW Wireless Sensor Network Module Pioneer?
Hugo
Hugo Santos
Message 5 of 18 (3,438 Views)
Reply
If you just want to do that, you don't need the module.
Message 6 of 18 (3,436 Views)
Reply
So to get in an output voltage value, I'll have to do?
Hugo
Hugo Santos
Message 7 of 18 (3,434 Views)
Reply
Highlighted
Can you tell me exactly what you need ?
If you want to set an ouput voltage value, it's impossible. The only outputs avaliable on this node are digital outputs. When you set it to True, the output voltage is 12V.
Is that what you need ?
Message 8 of 18 (3,431 Views)
Reply
I needed a hardware trigger voltage of 24Vdc, it is possible?
Hugo
Hugo Santos
Message 9 of 18 (3,428 Views)
Reply
No, it's impossible. Moreover, do not think of using two outputs in series connection. Grounds are internally linked so if you do that, you will do a short.
Message 10 of 18 (3,426 Views)
Reply
