NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
kdtung
Using WSN for accelerometer sensor
I plan using the WSN for accelerometer sensor, however I cannot find the Node using for this purpose.
I wonder if the WSN can use for acclerometer or not ?
Thanks a lot
Active Participant
Re: Using WSN for accelerometer sensor
Thank you for your post.  You can use the voltage or the voltage-ohm nodes with process current resistors to measure overall vibrarion from IMI-Sensors or Wilcoxon.  I have attached a brief summary of the components of a system with links to sensors, recommended WSN nodes, and LabVIEW programming tools.
Preston Johnson
Global Program Manager
Asset Monitoring Systems
Vibration Analyst II - www.vibinst.org
preston.johnson@ni.com
www.ni.com/mcm
www.ni.com/soundandvibration
512-683-5444
Member
kdtung
Thank you,
I will try this way.
Member
kdtung
Hi Preston,
The sensor in your summary is velocity sensor, not accelerometer sensor.
Now in our Lab, we use the accelerometer sensor such as link below
http://www.imi-sensors.com/Industrial_Accelerometers/Low-Cost_for_Permanent_Installation/Low-cost_2-...
The output of the sensor is voltage, not current. So, whether can I connect this accelerometer sensor to the node WSN 3226 ?, and do I need any special connector ... ?
Active Participant
The accelerometer you reference is a high bandwidth accelerometer and will require much higher sampling rate than available with the WSN product line.  You may want to consider a low cost CompactRIO system with a wireless gateway of sorts.  Consider the brief overview in the attached pdf.
Preston Johnson
www.ni.com/mcm
512-683-5444
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
