11-14-2013 10:56 AM
Hello all,
how can I undeploy a .vi file from a WSN node that I don't need anymore?
I have tried undeploy but it didn't work. Still in the WSN configuration the node appears with a .vi deployed on it.
Thank you in advance!
Kostas
11-14-2013 02:04 PM
You can clear the VI on the node by holding down its reset button ~10 seconds. This will cause the node to factory reset with no VI on the node. You will know if it worked if the node's signal strength LEDs begin flashing Outside LEDs<---->Inside LEDS.
The Undeploy option in the LabVIEW project undeploys I/OVs that may not be used anymore. It does not undeploy the VI as you have discovered.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Network DAQ/Wireless
11-17-2013 04:15 PM
Also, if you do not have a physical access to your node, you can "upgrade" the firmware with the default one via the web interface or the monitor.
Matt
