Initially, i want to transfer the compressed audio file from one PC to another PC.
I thought about two schemes:
(1) each PC will be connected to a gateway, between the gateways there will be multiple NI-nodes 3202 which will multi-hop the data.
doubt: can nodes under different gateways can communicate between each other as they may belong to different groups.
(2) NI-3202 will be interfaced with PC (I see no serial port on the nodes, only analog and digital I/Os are there), between the end-nodes there
will be multiple nodes to hop the data.
My ultimate goal is to capture the audio stream from the NI-node deployment field and transmit it back to the gateway through multi-hopping.
According to some benchmark document on NI-3202, there is a very low upper-limit (<10000 samples) on the sampling rate of the analog and digital I/O of the nodes.
So that can be a bottleneck in transferring the audio file.
Is there any other way around?
Warm regards,
Abhinav
Thank you.
