NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
To programmatically get the Serial Number of the WSN nodes?
Hello there!
Does a WSN node know it's serial number either natively (in firmware) or via the WSN gateway at boot time of the node? I'd like the node to know what it's serial number is and use to for debug and User App msgs. Think about a large scale mesh with many nodes.
One can certainly find all nodes (WSN Get Node Info.vi) on the Host application side and then propagate the serial number to each node (WSN Send Message.vi) as a User Message and make that a WSN node global variable... this seems like a lot of work.
Is there any easier solution?
-Chroma
Member
TimothyA
Re: To programmatically get the Serial Number of the WSN nodes?
Hey Chroma,
For non-programmable nodes, I think the WSN Get Node Info.vi will be the easiest way to obtain the Serial Number for each of your Nodes.
If you're using programmable nodes, you can always create a constant value for the Serial Number on the Node. You could also create a User Defined Variable for the Serial Number that your Node can publish to the gateway and use within its own code.
Tim A.
Member
I understand your comments but it's still not clear to me whether the NI serial number (on the label on the side of the WSN node) is actual burnt into flash or firmware during manufacture.
-Chromaburst
Member
TimothyA
Hey Chromaburst,
I'm sorry I wasn't able to address your question in the first post. I'm not sure whether the Serial Number is set into the firmware or into some form of Read-Only (EEPROM) memory on the WSN node but I would definitely say it is stored on there permanently in some way. I suspect this because of how we can connect a node to a Gateway within the Measurement & Automation Explorer (MAX). Whenever you connect your Gateway you then detect and associate your Nodes with the serial number.
Tim A.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
