NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Archie Flores
The WSN Gateway folder doesn't show up in Add Targets and Devices
Hi, I'm making a Wireless Sensor Network and I got to make the comunication of the NI-9792 with the server and with the nodes of the network. The problem is that I have to make the project in LabView to start gathering data, but in the Add Targets and Devices window I can't find the WSN Gateway folder, it doesn't show up where it is supposed to be. What could be the problem? I'm attaching images about the ideal situation and my situation.
Active Participant
PackersFan
Re: The WSN Gateway folder doesn't show up in Add Targets and Devices
Does WSN Gateway show up if you select New Target or Device?
My guess is not.  That would indicate that you don't have the WSN drivers installed properly.  Did you install them after LabVIEW?  Is the version compatible with your version of LabVIEW?
EDIT: In the future please post this, but I was able to look at your screenshots and figure out you have the 1.2 WSN driver and LabVIEW 2011.  These are not compatible.  You will need the 1.3 WSN driver.
Chris
Certified LabVIEW Developer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
