Wireless Sensor Networks
Remote front panel with WSN 1.4
Thank you Brian,
If it's possible, could you post a note here when the solution will be available. This way it will pop in my emails and I'll mark the post as solve.
Thanks again
Mathieu
Message 11 of 15
(3,129 Views)
As soon as I verify a solution I will post back and send you the solution.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Network DAQ
Message 12 of 15
(3,125 Views)
Any news on that issue? I'm running into the same problem...
Thanks!
Message 13 of 15
(3,096 Views)
Mathieu and vgravel,
Please check your Private Messages.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Networked DAQ
Message 14 of 15
(3,062 Views)
Hello Brian,
I'm answering you here because we cannot add attachment in private message (?).
I did like you suggest but still get the same error ("Server does not support remote panels").
I attached a zip file with all the config that I could think that would be usefull. Maybe I'm missing something or the error is related to something else?
Thanks for your help!
Vincent
Message 15 of 15
(3,052 Views)
