Wireless Sensor Networks
Reading sensors using MDA300ca in LabView
Dear all,
I have mda300ca and I need to read its sensors using labview, Are the crossbow xmesh drivers that support  mda320 compatible to be used with mda300 ? many articles and posts mentioned reading from mda300 but it's not clear what drivers have been used
thanks for help
(5,132 Views)
Hello uniquedogma,
From what I was reading in different forums interactions (here) you can modify the code that is inside of the driver (you can modify the vi's for the MDA320) in order to have your device running with it due to the MDA300ca it's not supported by the driver, but from what I understand the MDA320 works similar as your device so this might be a possible solution fort his.
Luis Garcia
(5,068 Views)
