07-07-2013 07:28 PM
Hello all,
as shown in the "Under the hood" section I am trying to set my transmitting signal interval close to 60 seconds without "hurting" my sampling rate interval. So I'm trying to do what is done in the "Under the hood" section and just set a case structure that will send the radio message when the sampling case has run 60 times (assuming 1 S/s) but as shown in the pictures attached I have no option like this from the Radio Messages .vi. My WSN Node is an NI-3202 voltage node.
Thank you very much!
07-07-2013 10:56 PM
Same problem i am facing from the last few days. One thing i would like to ask you is when you deploy your code on WSN Node and on deploying does it RUN, In my case it gets deployed but it won't RUN. Help me out
07-07-2013 11:52 PM
07-08-2013 07:47 AM
But after deploying the .VI on the node i won't be able to see the .VI in running Mode and can you tell me how to use the Radio messages in the node .VI and also how to send and receive string based messages and where can we view those messages, I hope you have done all those things. Thanking you
