Wireless Sensor Networks
Latest firmware for 3226 node
I just update to Labview 2015. I update the module Pioneer to 2015 also and the software inside my 9792 Gateway. When I tried to update the firmware in my 3226 nodes, it remains to 1.4.0f0.
Is there a 1.5 firmware ? If yes, how can I get it ?
Thank you
(5,705 Views)
Hello MaLac,
In order for your WSN hardware to be compatible for use with LabVIEW 2015, you will need to download the WSN driver that is compatible with it. The latest NI-WSN driver version is 15.0. I have provided a link to the download page for this driver below.
NI-WSN 15.0 Driver
http://www.ni.com/download/ni-wsn-15.0/5730/en/
This driver will be able to provide with the files that you need to update your firmware. Once you download the driver, update your firmware by following the KnowledgeBase I have provided below.
How Do I Upgrade the Firmware On My NI WSN Measurement Node?
http://digital.ni.com/public.nsf/allkb/88C1DB7FA2F1041286257CB600553687
Please let me know if you have any additional questions about this information or this process.
Gabby
National Instruments Applications Engineer
(5,693 Views)
Finally, I had done everything right. It seems that the node firmware didn't change since a couple years. The most recent firmware is still the 1.4.
Thank you
Mathieu
(5,643 Views)
That is correct MaLac. The latest firmware is 1.4
(5,225 Views)
