Wireless Sensor Networks
LabVIEW 2011 WSN Module?
I just received a NI WSN Starter Kit and it came with LabVIEW 2010 evaluation disks and the WSN Module Pioneer 2010. On my work laptop I have recently removed LV 2010 to upgrade to 2011. The WSN Module won't install without LabVIEW 2010...
Is there a walk-around or a new version of the WSN Module for LabVIEW 2011? Or do I have to install LabVIEW 2010 again?
Thanks.
(5,376 Views)
Hello GrigS,
This is Andrew Brown, an Applications Engineer from National Instruments. There is a newer version of the NI-WSN driver (1.3) that is compatible with LabVIEW 2011. You do not need to install LabVIEW 2010 again.The download page for the driver is:
NI-WSN 1.3 - NI Wireless Sensor Networks - Windows 7/Vista/XP x86
Please note the installation instructions on the page are:
Installation Instructions
Perform the following steps to install NI-WSN 1.3.0:
  1. Install LabVIEW
  2. Install LabVIEW Real-Time Module (required for NI 9792 and NI 9795 support)
  3. Install NI-RIO Driver Software 4.0 or later (required for NI 9795 support)
  4. Download and run the self-extracting executable NIWSN130.exe. This will install NI-WSN 1.3.0 and all necessary driver files.
Andrew Brown
Software Engineer
(5,367 Views)
