07-06-2012 11:00 AM
Good afternoon,
I've had several times on the gateway, and a moment's notice can not connect it to PC. Can you help me? Attached sending the image of the error reported.
Regards
07-06-2012 09:21 PM
Hi !
Try to change the IP of your PC. In Network and sharing center, go in the properties of your connection, in ipv4 protocol, add an alternate private ip realy near the one of your gateway, i.e the same first 3 numbers. Then reset your gateway. At this time you may be able to connect to it, or at least partially, If you see it in MAX but can't connect with labview, go in the web interface (enter the ip in your browser) and change the subnet mask of your gateway to 255.255.255.0 in should work.
I have to do this each time I plug a different gateway into my PC...
Hope it will work for you.
Mathieu
07-12-2012 09:23 AM
The problem is continue. I try the anyways to connect the WSN 9791 in PC.
It is inexplicable, because they consigui used previously, and now a moment's notice, failed to get connection.
Regards
