NI Home
Cart Cart | Help
You are here:
Reply
Member
hugosantos
Re: How to make the connections on the outputs of the letter wsn 3202?
Good morning.
I want to report that the letter is already running. But the answer is in the order commanded a little slow. Is there anyway to control this time?
Greetings.
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Active Participant
PackersFan
The response time is controlled by the update rate of the nodes.  I believe you will find this in the gateway properties, though it may be in the node properties.
Chris
Certified LabVIEW Developer
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
