04-20-2012 06:53 AM
Goog morning Engineers,
How to make the connections on the outputs of the letter wsn 3202?
04-21-2012 03:22 PM
Connections to what? What are you trying to control/measure?
04-23-2012 08:01 AM
The situation is as follows, I intend to obtain a value of output voltage of the deviceWSN 3202, through a condition imposed in labview (example attached), I intend tooperate a relay. But until now still can not get any kind of value.
Greetings.
04-23-2012 08:12 AM
Attached sending
04-23-2012 09:08 AM
Okay, that VI looks fine.
Are you not seeing the output values?
Do you read good input values?
04-23-2012 09:21 AM
Yes I see the input values.
But the doors do not get any output value.
(Attached will the calls made.)
04-23-2012 09:42 AM
You need to supply DIO Power (pin 17).
04-23-2012 10:56 AM
I've done that. I called the Power DIO - DIO 0 and not obtained anything. Will have to give the value in the program?
04-23-2012 12:17 PM
Sorry, I'm very confused by your response.
You should not need to set anything about the power programmatically, just wire up a power supply to DIO Power and the DIO Ground. Then your DIO lines should be able to output values.
Also, I do think you may need to setup the line as output. This would be done from the project. I don't remember which element it is, but it should be in some Properties menu (probably for the specific DIO line).
04-23-2012 03:53 PM
Thanks for your reply, helped a lot. I'll try again, and then say what was the result.
Regards.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
