11-01-2011 02:07 PM
I have the WSN packet for my SDP I want of prgrame one of the nodes to recive a logic order to see if the tempreature exceed certain limit on the Ac switch While it is below that certain level off the switch ... (of course that# depending on the tempreature sensor the packet has and i have already programe it on the labview to sence the temperature and it does work ... hopefully my question is clear 😄 << wating yr quik response ,,,
thanx
11-02-2011 10:11 AM
Hi Eman sa3d,
What version of LabVIEW are you working with and what WSN nodes?
I ask because sending user messages has gotten a lot easier in WSN 1.3 and the new WSN Module for LabVIEW 2011.
Have a great day,
Chris V
11-02-2011 10:43 AM
I'm Using LV version 2010 ...And for the WSN I think what I'm using is called NI 9792 ...??
11-02-2011 11:07 AM - edited 11-02-2011 11:09 AM
11-02-2011 11:11 AM
sorry 4 that...yes I checked it's WSN 130..So now how I can programe it to send an order to the node to check if the temp..below of greater than certain temp..to on of off the AC ??
11-03-2011 10:44 AM
Hi Eman sa3d,
If you are using LabVIEW 2010, it will be a little more difficult. You will need to program the node to use one of the existing IO variables to send your message. I sounds like you only need to send a boolean, so I would recommend "hijacking" one of those lines to send your message.
Check out this example which sends average data back over the analog variables: https://decibel.ni.com/content/docs/DOC-6124
In your case, from the host you simply need to write to a designated digital line on the module, and then on the node you need to read that digital message and make decisions based upon its value.
Have a great day,
Chris V
11-06-2011 08:36 AM
ok now I have LV 2011 ...can you explan to me how to make it ?!
