07-05-2012 08:50 AM
Good afternoon, engineers,
I have a WSN and WSN-9791-3202. When there is a loss of signal between them I can see this disconnection.
And when there is loss of signal between the PC and the WSN-9791, ie when disconnected the ethernet cable from the PC?
How do I see this error? And why it continues to be a connection between the WSN and WSN-9791-3202 if there is no connection to the PC?
Regards.
07-09-2012 08:08 AM
Hello Mr Santos,
If the 9791 loses connection to the PC, you should get an error message (see the list). You can see this error on the error cluster :
It is normal that there is no error when the PC loses connection with the gateway 9791. The 9791 publishes values over the network and it doesn't wait for a PC to do it.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
07-09-2012 11:52 AM
But how do I send this information to the node 3202? Example, I have a node to Acquire temperature, and do not have the pc on the side, just got a warning light connected to the output node 3032, which warns you when it loses the signal between the gateway node 3202 and 9791. If you lose the connection between the gateway and the PC, I can not send any signal, right?
Regards
07-30-2012 10:06 AM
Sorry for the answer delay. If you want the node to detect that there is no communication between the gateway and the PC, I guess you will have to use LabVIEW WSN Pioneer.
I'm not sure if it is possible but using a message sent from the PC could be interesting. You could detect if after a certain time you didn't get the message. If you still want to try, you can have a look there :
Getting Started with the LabVIEW Wireless Sensor Network (WSN) Module
The LabVIEW Wireless Sensor Network Module - Under the Hood
Regards
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
