Wireless Sensor Networks
Acquiring data from all the analog channels of NI-3202 NODE using a single sensor
Hi all,
I would like to know that can i be able to get the data from all the four analog channels of NI-WSN node 3202(analog input node) connecting only single sensor on the analog input and connecting all the remaining analog inputs using wires and also shorting the ground pins corresponding to each analog input pin.
By configuring the each channels like 0.5 sec delay for every analog channels to acquire data. can we get the sensor data from all the channels by doing this. basically here i am trying to increase the minimum sampling rate of the ni-wsn NODE 3202 which is 1s.
I this approach is correct or we cannot do this.
Message 1 of 1
(5,193 Views)
