09-01-2012 08:14 AM
Hi all,
I recently started using NI WSN. I managed to acquire signals by the WSN Gateway from multiple end nodes.
I've read on ni.com that in order to achieve more than 8 end nodes we should use some nodes as routers.
Now I'm wondering how to exactly do the configuration of the WSN node to make it work as a router not as an end node.
I'll really appreciate if anyone could help.
Thank you in advance.
Gevorg
09-03-2012 02:25 PM
Go in MAX or in the web interface via your browser, select the node you want to change into a router and just click "change network mode".
Have a nice day
Matt
09-04-2012 09:15 AM
More info about WSN setup can be found here:
http://www.ni.com/white-paper/11211/en
09-05-2012 01:17 AM
Thank you about this.
Unfortunately yesterday I faced another issue. Does anyone know is NI-WSN 1.3 driver software supported by Real-time 12 ? Is there any updated version for Real-time 12?
Thank you
09-05-2012 04:18 PM
The NI-WSN driver for LabVIEW 2012 should be released soon. For now, you can use NI-WSN 1.3 with LabVIEW 2011.
09-06-2012 01:35 AM
Thank you Zach P.
Gevorg
