Webcast Wednesday Discussions
Webcast Wednesday Contest # 37
Ans 1- A
Ans 2 - E
-Venkat
Message 11 of 15
(2,669 Views)
1.c
2.d
Venugopal
Message 12 of 15
(2,669 Views)
1. C
2. D
Message 13 of 15
(2,669 Views)
Message 14 of 15
(2,669 Views)
The Answer for 1st Question is option (c): Last Value of Random 1+ Random 2
Description: When you press Boolean 1 and Boolean 2 at the same time (that means you off them simultaneously) and then off Boolean 3 switch then you only get the final result if you don't press them simultaneously you will not get the result. Last Value from Random 1 and random 2 are taken and displayed as result.
The Answer for 2nd Question is option (d): if you disable auto-indexing on the right side of the For Loop, the output is still a 1-D Array
Description: When you disable auto-indexing, the value is set to last value and changed from array to numeric constant.
Message was edited by: amansinghla
Message 15 of 15
(2,669 Views)
