08-04-2011 07:02 AM
I want to create a silent installer for NI software, which is licensed via VLM. When I start to generate my specific nisuite.xml file, I get the message to use the parameter /groups. Unfortunately I do not find any hints how to use this parameter, the web page I found using the hints given in the pop-up window is not helpful for my case.
To specify my needs: I am using an Academic license and I want to generate an automatic installation for computers in a lab, which should all have the same installation, independent from the user. Therefore it would be fine, if every computer would get his license automatic without any input during the installation.
Michael
08-08-2011 08:23 AM
Hi Michael,
the process for creating silent installers with different options for VLM- or non-VLM- based installers
is described in these KBs:
http://digital.ni.com/public.nsf/allkb/878FC4C3740
http://digital.ni.com/public.nsf/allkb/AA2371E815A
http://digital.ni.com/public.nsf/websearch/D9DE5FB
please walk throug the process and try it out.
Marco B. NIG
09-27-2011 08:41 AM
Hi Michael,
I remember having had a similar (maybe the same) problem. I think, the group parameter does not appear anywhere in the documentation.
At the moment, I have no access to what I did back then, but I remember I had to experiment with the /groups parameter.
I think I used either /groups or /groups none on the command line
But don't beat me if it's not.... ;-) As soon as I remember, I'll let you know!
Oli
09-28-2011 01:58 AM
Hi Michael,
I guess you tried creating the spec file usind something like
setup.exe /generatespecfile c:\temp\spec.ini
If you get an error concerning groups you might want to try
setup.exe /generatespecfile c:\temp\spec.ini /groups ""
Can you check if this works for you?
Good luck
Oli
09-28-2011 05:10 AM
Hello Oli,
meanwhile I found a hint on a NI webpage (don't ask me whichh one). The solution there was similar to yours, to use the parameter
/group {}
in the call of setup.exe. This worked fine.
Thank you for your answer!
Michel
01-10-2013 04:13 AM - edited 01-10-2013 04:13 AM
Think thats from here:
Why am I Unable to run a Volume License Installer Silently Without Using Groups?
http://digital.ni.com/public.nsf/allkb/0DA0176CDD9
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
