You do not need to reinstall the software to license it. I have a couple of ideas. First, you or the user could manually set up the local NI License Manager to point to the volume license server. The steps are fairly simple, you just need to know the name of the server and the main licensing port. You can see the main licensing port in VLM by going Tools > Preferences. In the General category, there will be Server Settings where the main licensing port is listed. The default is 27000. Here is a KnowledgeBase article with the steps to set up the client machine to point to the server: Setting up Access to a Volume License Server from the Client Machine
I think setting it up manually would be the easiest option, but there is a second option. Since you've made a volume license installer (VLI), running the vlmclient.exe
should actually automatically set up the server connection on the local/client computer. I haven't tried this myself before, but it should work. For more information about that, take a look at this page in the VLM Help: Configuring Client Machines Automatically
Hope this helps,
Taylor B.
