10-08-2015 02:21 AM
I'm trying to set up a Jenkins Build server but I'm facing a licensing problem. LabVIEW can not find a valid license when started by Jenkins.
Neither a license directly from the server nor a disconnected license we created especially to try.
I have tried to start the Jenkins service with my user credentials, but this does not improve the situation.
Is there a possiblity to start LabVIEW within a specific user context? Sth like LabVIEW.exe -user:JohnDoe to enable correct license retrieval?
Cheers
Oli
10-09-2015 03:52 AM
Hi Oli_Wachno,
maybe this presentation or the following Getting Started will help you with your Jenkins issue.
Best wishes
Tenshinhan
10-09-2015 04:00 AM
Hi Tenshinhan,
thanks for the reply.
I'm already active in the threads, you've referred to. They led me into this particular forum
Oli
10-09-2015 04:03 AM
So to answer your question, it is not possible to change the license by a specific LabVIEW Call.
The licenses are stored in the license manager or an Volume license server.
There they can be activated.
Normally you will use a computer based license if several users are using LabVIEW on the same machine.
