NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
~jiggawax~
Dynamically Deactivate License
We moved a whole bunch of our machines' licenses to a VLM.  Now we need to go deactivate all the local licenses.
Looking through the command arguments for nilmutil.exe it doesn't look like this is an option.  Does anyone know of a way I could create a batch file to dynamically deactivate licenses?
I tried just changing the pernanent word in the license file to be 1-jan-1900 but it looks like the SIGN variable needs to be changed as well.  Not sure how to do that.
I'm also open to replacing the file with a default one but not sure if the same default file will work for multiple machines. Or if that is generated from the installer based on the computer name.
Ideas?
Thanks a bunch,
jigg
Test Development Engineer
L-3 Communications
Active Participant
~jiggawax~
Re: Dynamically Deactivate License
[ Edited ]
Found this: http://digital.ni.com/public.nsf/allkb/6BF2C6CF85611A7B86257107005DEEFA
It may work....
I'll give it a try.
jigg
L-3 Communications
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
