Volume License Manager and Automated Software Installation
Bundle the LabVIEW Platform DVDs and Device Drivers DVD into One Volume License Installer
We are trying to bundle the ASL DVDs into one volume license installer (VLI) as described at knowledge base document ID 4RDAA91O but the directory structure at Spring 2010's NI Device Drivers DVD is completely different (there aren't DCD-MonYr-x folders anymore). Is there any new documentation?
(8,915 Views)
Customer called NI and was explained how he can do this.
Thanks.
Best Regards
Osvaldo Santos
(8,907 Views)
Hi Osvaldo,
Can you post the solution to this here please?
Vikas
(8,286 Views)
Please share the solution with us Osvaldo !!
Peter
(7,966 Views)
As no one has responded I thought I would close the loop on this so that everyone can benefit on the current way to do this.
look at DOC ID: 4Q8HDL1O located here: http://digital.ni.com/public.nsf/allkb/A67783E7861A0509862574DD008083CF
It show how to do this for VLM 3.0 and is what I have used succcessfully many times.
One caveat is that the VLI will weigh in at more than 15GB if you include most common LV pieces and more so if you want all modules and toolkits. I have seen VLI's of 30GB when I wanted a fully loaded system VLI.
Hope this helps.
(7,114 Views)
