Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
simulated imaqdx cameras
This idea is something I have implemented in house and posting is motivated by the following discussion:
http://forums.ni.com/t5/Machine-Vision/Simulate-GigE-Vision-Basler-Runner-Camera-ruL2098-10gc/m-p/30...
I would like to have the ability to add a simulated imaq camera in max to use with the imaqdx driver.
The camera should be able to specify wither it is linescan or area scan, as well as sensor size and specifications.  The simulated device should support the basic property nodes (AOI, exposure line or frame rate ..... could even have a xml for iGenCam).  Ideally the source of the image (directory) could be specified so that grabs or snaps would play back previously acquired images or a test pattern could be selected instead.
I might be asking for too much, but this allows for offline testing on vision systems, something that is common after deployment.
