Vision Idea Exchange
varga.sm
VBAI 16 bit tools
Status: Completed
This is now available in Vision Builder AI2015. The Threshold, and Detect Object steps were updated in Vision Builder AI 2015. The Find Edge, Find Circular Edge, Advanced Straight Edge already supported 16-bit images in Vision Builder AI 2014. Thanks for the suggestion.
2
VBAI
16 bit support for thresholds, detect objects, etc.
Advanced edge tool will not work on low contrast 16 bit images unless the Straight Edge Settings; Minimum Score is set to 0 (make 0 default then?)  Also the Advanced edge tool max score is 1024 so it cannot find edges with stronger transitions which often occur in high contrast 16 bit images.
5 Comments
Nate.H
Status changed to: In Development
Nate.H
Status changed to: New
Nate.H
Brad
We added 16-bit support in Vision Builder AI 2014 SP1 for the following algorithms:
- Find Edges
- Gray Filters
- Advanced Straight Edge
Do you use the Auto Threshold method, or would just having 16-bit support for simple threshold and local threshold be sufficient?
Brad
Status changed to: Completed
