Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
User Kudos Count
1
Provide a VI in VDM that vould return an array of strings of all in the image used overlay Group's
Functions* that insert overlay's into images can define a Group, so later you can e.g. delete the whole overlay group at once. Currently there is no VI that would be able to get a list af all Group names preset/used in the image (if you e.g. load an image saved with overlay's and you want to know the Group names, so you can access theyr properties). It could look like this:
Then it would be also easy to get properties if all of the overlay group's (with IMAQ Get Overlay Properties VI)... This VI could also return a array of integers, that would give information about how many Bytes each overlay group uses in memory - for debuging puposes, or if you have some memory shortage problems...
IMAQ Overlay Arc
IMAQ Overlay Closed Contour
IMAQ Overlay Line
IMAQ Overlay Oval
IMAQ Overlay Points
IMAQ Overlay Rect
IMAQ Overlay Text
Jozef Lipták
