Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
Particle Analysis Input Image Type
Supporting only binary images as input type for the particle analysis is reducing the use cases where this functionality can be used. In many segemtation methods, e.g. superpixel segmentation or watershed segementation, the segmentation result is a labeled image. Being able to perform particle analysis on labeled images would enhance the modularity of this function. Since the particle analysis in internally performing probably a labeling anyway, and in many cases, the label of an object which is to be analysed is known too, it could also reduce the computational cost of this function.
