Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
Improved Image Zoom Tool
The zoom tool of the image display control is antiquated. Currently (Vision 2016), you select it and then click in the image to zoom by a fixed amount.
Consider upgrading its capabilities to match modern UIs:
- Selecting a rectangular ROI with the zoom tool should zoom to that ROI, i.e., the ROI should be expanded to fill the imag display control.
- support mouse wheel (and touch screen if needed) to act as a zoom in and out no matter which tool is selected.
- support fixed aspect ratio hot key (e.g. Ctrl key): zooming with the above ROI selection while the hot key is pressed will zoom the image to fill the display with the largest (or smallest) dimension of the ROI.
Feel free to add suggestions below.
1 Comment
Member tomsze
This is just what I want. I dont want to click ten to twenty times to zoom on tiny thing in high resolution image. I want to give you many many kudos too..
