Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
User Kudos Count
1
1
1
Color Palette Display
The Image Display control (IMAQ Image.ctl) allows the user to change the color palette.
Like for the Intensity Chart and Graph objects in LabVIEW, it would be useful to add a color scale object to the control in order for the user to be able to visualize the color <-> value correspondance.
Like for the Intensity Chart and Graph objects in LabVIEW, the color scale should also allow the user to set the display range (min and max value) as well as the out of range color values.
