Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Top Kudoed Authors
Adding Option for Display while Right clicking on Image Indicator
This idea is to have an option in the Image Indicator to change to Image Display.
Currently to get Image Display Developer needs to right click on the Front panel of Image Indicator -- Replace---Select Vision and the needs to select the kind of diplay needed.Image Display.PNG
If by default the right click option provides Display also as an option, then its easy to navigate in single selection.
2 Comments
Active Participant udka
Yes. Long back i posted similar idea and got rejected because it didn't get enough kudos
Edit: Here it is https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Image-indicator-Default/idi-p/2664707
Active Participant PalanivelT
Thought its really useful during development,will hope for the bestSmiley Happy
