10-29-2015 08:38 AM
I'm having trouble getting Virtual Bench to trigger on the FGEN Start in labview. I can get it to work on the GUI.
I did the riIght click and IO name filtering to turn on the option. But when I select it, it does not trigger, so it does not run.
Any ideas of what to check or do?
AM
10-29-2015 01:44 PM
Is the function generator enabled?
When I enable or disable the output of the FGen, the scope will trigger or not:
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
