08-11-2008 07:07 PM
08-12-2008 08:33 AM
08-12-2008 04:39 PM - edited 08-12-2008 04:40 PM
Hello Dulcy,
In order to use your USB-6008, you will need to have the appropriate drivers installed. The USB-6008 requires the NI-DAQmx Driver to be used. Virtual Bench supports only the Traditional DAQ driver. Since the 6008 is not supported in Traditional DAQ (you can check this from the DAQmx readme), you will not be able to use Virtual Bench with your 6008.
Instead, the DAQmx driver includes a 30 day trial to the full version of LabVIEW SignalExpress. For a list of features between SignalExpress and SignalExpress LE check out this article. Basically, SignalExpress LE provides similar functionality to Virtual Bench but includes support for newer NI devices. It is included on the driver CD you received with your 6008 and is also included on the download of DAQmx that can be found at the link about. Let me know if you have any questions.
08-13-2008 04:58 PM
08-18-2008 03:45 AM
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
