NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
TI RFID
gpib data log interface with ESPEC ESX-3CA
Is it possible to use virtual data logger to
interface(GPIB) with this chamber?
Espec Temp/Humidity chamber
Model: ESX-3CA.
We have labview but prefer not to
spend time writing a new program
if one exist. I have used data logger
for simple apps- temps only-
but I need to log if an alarm was activated or
the chamber shut down. I need to monitor
the status every 15-20 minutes and log.
Or perhaps via 232? I would appreciate any
suggestions.  Time is critcal and short
and would like to have this running this
weekend.
Rudy Zamorano
TI RFID Systems
Engineering Lab
Plano, TX
Member
Kennon_Cotton
Re: gpib data log interface with ESPEC ESX-3CA
Rudy,
VirtualBench-Logger only supports NI Data Acquisition devices, older ones at that since the software last revved about 7 years ago.  It won't support your GPIB instrument.  Nor will our newer datalogging software VI Logger.  My recommendation is to find a LabVIEW instrument driver for the device and see if there are any examples with it that you could get started with.
Kennon
Member
Kok Chywn
I have the same problem as Rudy, except that I want to use LabView as a data loging and control system for the same Espec Chamber. Would LabView be able to interface with the Espec chambers and do that? if so, how would i go about doing it? Thanks in advance.
Member
JaredRo
Kok Chywn,
Just to clarify, are you askig about using VirtualBench with the Espec chamber, or just LabVIEW by itself?  As Kennon stated, VirtualBench is only designed to work with NI Data Acquisition hardware and will not work with your instrument.
However, page 7 of the catalog for Espec Temperature and Humidity Chambers (http://www.espec.com/images/uploads/files/e_catalog_platinous.pdf) states that there are LabVIEW drivers for GPIB communication with the ESX-3CA.  This implies that you should be able to remotely control the device using LabVIEW.  Espec will need to provide the driver for you.
Good luck with everything.
Jared R.
Precision DC Product Support Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
