NI Home
Cart Cart | Help
You are here:
Reply
Member
VT_Tim
convert .ref files into a usable form
I am trying to use MatLAB to perform calculations on information that is collected through VirtualBench's DSA. When I save the Waveform's in the DSA it saves them as a .ref file. How can I get this into a usable MatLAB form? or convert it into anything else? I am running VirtualBench V2.1.1 on a Windows 95 machine. If you need any system specs please let me know. Thanks
Active Participant
Otis
Re: convert .ref files into a usable form
Tim,
I just talked with some of the other engineers here and one of our Application Engineers (Scott) mentioned that he answered this question for you in an email.
Would you mind posting his response so that others can see the solution?
Thank you,
Otis
Training and Certification
Product Support Engineer
Member
VT_Tim
Here is the e-mail I received. Thanks for the help.
Tim,
That's a good question. The solution to this problem is to use
File->Generate Report to save the waveforms into a .txt file in ASCII
format. This will allow any application capable of reading an ASCII text
file to import and manipulate the data. The .ref file is created for use
solely within the VirtualBench application and is not a standard file
format, thus there is not an easy way of converting the contents of that
file into something that can be read by a third party. Using File->Generate
Report should solve your problem.
Best Regards,
Scott Teigen
Applications Engineer
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
