When I load VirtualBench 2.0, I get the error "VirtualBench cannot find any configured DAQ hardware in this computer. You will need to exit VirtualBench and run the NI-DAQ Configuration utility before proceeding". I am trying to read my NI 4350 PCMCIA card, and using Windows 2000 with the driver software version 6.7. Before, I had a similar error using my a newer computer with Windows XP and the driver software version 7.4. The card is older, so should I be using older drivers? Anything else that might work?
The Measurement and Automation software recognizes the card and the test resources and test panel both work fine. Thanks for any input.
