Hi, we use Virtual Bench Logger and usually use 6 x channels to measure deflection from strain gauge transducers. It can be a pain to zero them off via the offset function at the start of each test. Is there a function that can be added in to provide an "instant zeroing" of channels?
I have been looking into this query this morning and I can not see any add on tool or function for Virtual Bench Logger that allows you to quickly zero your channels. It appeares that manually offsetting your readings at the beginning of each test is the only way of zeroing your channels.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
