NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Curt D
Why does VirtualBench Logger read -273.15 degrees C when measuring temperature with a thermistor?
[ Edited ]
I am trying to switch from using thermocouples to thermistors. I am using a TBX-68T terminal block and an NI 4350 voltage meter connected to a computer running VirtualBench 2.6 via USB. When I plug a resistor of known value into the TBX-68T and excite it with current from the IEX0- and IEX0+ ports, VirtualBench will display the correct value for resistance. Then when I replace the resistor with a thermistor, VirtualBench will show that the resistance values vary inversely with temperature as expected. At this point, I change the VirtualBench settings to thermistor and input the correct A B and C values. When hit start, VirtualBench displays a static value of -273.15 degrees C. What is the problem?
Message Edited by Curt D on 05-16-2005 10:45 AM
Member
gaving
Re: Why does VirtualBench Logger read -273.15 degrees C when measuring temperature with a thermistor?
Hey Curt,
There are so many places where one thing might be wrong. Let's just start with the thermistor. Can you read a VALID resistance back with a handheld DMM? (not plugged into anything) When you connect it and start the acquisition, can you read back a valid voltage (across the thermistor) from the handheld DMM? Do you have the TBX-68T set up as an accessory for the 4350 in MAX? (Devices and Interfaces>>Traditional NI-DAQ Devices>>right-click on the 4350 and choose "Properties"). Try either way. Is your cable loose between the TBX-68T and the 4350? Are your limits set up correctly (the utility where you configured the A,B and C components)? What happens when you leave the A,B and C constants the default values?
Please let me know.
Sincerely,
Gavin Goodrich
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
