02-03-2016 10:19 PM
I would like to get an continous electrical resistance measurement so I connected my virtual bench to the labview.Hovever, it takes one sample per second. How an I increase this ? As far as I know , data logging stops at every 100ms for DMM in Virtual Bench so I should get a data at every 200ms.
02-04-2016 08:48 AM
Initiating an acquisition on the VirtualBench DMM is software-timed, but the acquisition itself is hardware-timed. Therefore, there is some maximum rate at which you can sample, but there isn't a way to guarantee a specific rate. There are also a few tips for acquiring faster with the DMM:
With this VI (which looks kind of ugly because of my timing), I am able to get ~4.8 Samples/sec on the VirtualBench DMM. With auto-ranging it was the same, but like I said you should be careful with that.
02-04-2016 09:12 AM
Thank you very much for your reply. May I kindly ask you to send it to my e mail address as block diagrams?
ozguratalay@seas.harvard.edu
cheers
02-04-2016 09:31 AM
NI provides several downloadable examples. Here is the one for the DMM: http://www.ni.com/example/52069/en/
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
02-04-2016 10:40 AM
Hi there
Thank you very much for your reply, I have one more question ,what did you write in iteration blog?
cheers
02-04-2016 11:15 AM
I'm confused by your question. What are you referring to when you say "iteration blog"?
Joe Friedchicken
