07-31-2015 04:21 PM
Has anyone looked at ethernet frames with the logic analyzer yet? Is there a good way to decode via the LabVIEW interface to VirtualBench?
Cheers,
Joe
08-03-2015 09:52 PM
Hi Joe,
I haven't been able to find much in terms of viewing ethernet frames through the logic analyzer, but found a community post that may be relevant--
http://forums.ni.com/t5/LabVIEW/LV-6-1-controlling-Logic-Analyzer-over-Ethernet/td-p/709968
08-04-2015 06:12 AM
Depending on what you are trying to do, you should look at WireShark. I don't know if it has anything you can automate, but it does tell you everything you want to know about the TCP frame.
08-04-2015 04:14 PM
I neglected to mention that this would be at the PHY level, so it would be the MII interface in this case.
The issue was resolved in the meanwhile. There was a misconfiguration for an RMII interface on a MII wiring.
If my thoughts are straight here, a logic analyzer at the R/MII level would have caught this issue. Actually, a scope of the clock would as well, as RMII is 50 Mhz and MII is 25 MHz.
Cheers,
Joe
