NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
azxs
How to accuire thermocouple based temprature DAQ USB 6009
I have got a USB DAQ card 6009. can someone tell me the pin configuration for the thermocoule i.e diffrential or RSE. Also I attached J type thermocouple but nothing is shown.
Pls Guide me.
Active Participant
Hal_L
Re: How to accuire thermocouple based temprature DAQ USB 6009
When you are acquiring data from a thermocouple, all you are doing is acquiring a voltage and then converting that voltage into a temperature. You can connect your thermocouple in either Differential or RSE mode and everything should be fine. Here are links to tutorials about field wiring and thermocouple measurements:
Field Wiring and Noise Considerations for Analog Signals
Taking Thermocouple Temperature Measurements
Hal L.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
