NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
bologna
Re: Upconvert from LV 5.1 to LV 2011
Respected Christian M,
Will it be useful if we convert probe.vi from 5.1 to 6 to 8 and then to 11, so that probe.vi run without any error.
yours friendly
vijay
Trusted Enthusiast
Christian Mergl
Vijay,
As I said I allready converted your probe VI. And no, it does not make sense to convert it through several versions.
A 5.1 VI just needs to be saved with 6.1 to be able to open it with later versions!
And if you get errors post at the LabVIEW forums so that somone can help you.
Christian
Member
bologna
I would kindly request you to convert the following filles from labview 5.1 to 11.0.
When i run probe.vi in 11.0 it asked of the following files.
I am here with attched 5.1 labview files.
Thanking very much and your timing help.
yours friendly
vijay
Trusted Enthusiast
Christian Mergl
Here it is.
Christian
Member
bologna
Respected Sir,
Thanking very much from your helping.
I would kindly request you to run probe.vi (5.1 version) in Labview 8.2, recomiling it and finally run in labview 2011 and save the file and then send to me.
I am here with attached probe.vi file.
Thanking You
Yours friendly
vijay
in the attached document you can check LabVIEW versions compatibility. Even if it hasn't been updated to LV
11.0, you can read that VIs you saved in LV 5.1 can't be loaded in LV 10.0 (so you can't load it in LabVIEW 11.0
too).
You have to try to run it in LabVIEW 8.2, recompiling it and finally you will be able to open it in LabVIEW 2011.
I hope this will help you
My name is mani vijay working in bologna university, italy. I would kindly request you to convert one file which is in labview 5.1 and i need to convert labview 11.0.
I have attached the lab view 5.1 version.
Thanking You very much for your previous help and spending valuable time for me.
Yours friendly
M. Vijay
Knight of NI
This thread is reminding me of a Merry Go Round.
For those of us who remember Merry Go Rounds.
Knight of NI
RavensFan
No one is going to be able to do this for you.
You already have numerous copies of probe.vi in newer versions that you can open.  People can't run your VI's because they don't have the hardware you have to be able to make it work.  So what you are asking for is a pointless exercise.
If you are having problems getting your code updated and running with all the help you've received so far, then perhaps it is time for you to hire a 3rd party LabVIEW programmer to assist you.
Member
pierroil
Hi everyone,
Can someone convert this library for me?
I need a 2011 version (or I guess 8.2.x works).
Thanks!
Alternatively, where can I download labview 8.2
Trusted Enthusiast
Christian Mergl
Please read the Version Conversion Board Rules and create a new thread at the Version Conversion Board with your request.
Christian
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
