NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
bologna
Upconvert from LV 5.1 to LV 2011
Respected Sir,
My name is mani vijay working in bologna university, italy. I would kindly request you to convert labview 5.1 to labview 11.0.
I have attached the lab view 5.1 version.
Thanking You very much for your help and time.
Yours faithfully
M. Vijay
Trusted Enthusiast
Christian Mergl
Re: Upconvert from LV 5.1 to LV 2011
Here it is
Member
bologna
Respected Sir,
Thank you very much for yur helping.
I would kindly request you to help me regarding importance of field point.
I am just now learning Labview 11.0,
I need to use labview 11.0 and carried out enthalpy probe for temperature measurement which is running before in Labview 5.1.
Kindly tel your suggestion written below
  • Install the software field point (field point explorer the older version among those present in the cd), in case you decide to use the version 11.0 we will install the latest version, if you adopt this last hypothesis must also update the firmware of the field point via software (see maximum care to avoid power failure at the field point when you are doing this operation).
Thanking You
Yours friendly
M. Vijay
Knight of NI
RavensFan
You really need to post that question in the FieldPoint forum.  This forum provides help in getting files converted as a favor, but to answer specific question about a product, you need to post in the forum dedicated to that product.
Is that statement you posted originally written in another language then translated to English?  If so, it is a rather poor translation.  The phrase "if you adopt this last hypothesis" makes no sense and is completely out of context with anything around it.
Member eie
Member
eie
hello
I want to convert my labview source which is in 5.1 version to 2011 version?
could u pls help me convert the programs.
thanks
Knight of NI
RavensFan
Start a new message in this board to ask for your conversion. Don't tack it onto the end of someone else's request, otherwise it will be overlooked.
Member
bologna
Respected Sir,
My name is mani vijay working in bologna university, italy. I would kindly request you to convert one file which is in labview 5.1 and i need to convert labview 11.0.
Thanking You very much for your previous help and spending valuable time for me.
Yours friendly
M. Vijay
Trusted Enthusiast
Christian Mergl
here it is, Christian
Member
bologna
Respected Sir,
Thank you very much for your kind help.
while loading the file in in labview 11.0,  i received one error message as
The sub VI could not be found when loading this VI. It may be moved , deleted or name may have changed.
will it be no probelm ?
Thanking You
Yours friendly
vij
Trusted Enthusiast
Christian Mergl
Missing Sub-VIs is just no problem if you don't want to use them in your actual application.
You could check from the VIs name in the context help window where they are from. Maybe it is some intrument driver missing?
However, if you are faced with other issues then Up- or Downconvert then please post your questions to the LabVIEW forums, not here.
Christian
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
