NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
GJAKLDFJG
Please down convert from 8.6 to 8.5, Ravens Fan already tried but even he is facing some problem
Can someone help me in downconverting this file. Ravens Fan treid downconverting it but then it was giving Labview error 3: front panel unable to load. Can anyone else try and see if there is a way to downconvert it succesfully.
I downloaded this file from ni.com and it is to grab and save video using usb webcam.
Thanks & Regards.
Knight of NI
Re: Please down convert from 8.6 to 8.5, Ravens Fan already tried but even he is facing some problem
The issue is that the VI uses IMAQ. Downconverting IMAQ VIs is notoriously difficult, and 99.99% of the time you need to have someone who has IMAQ installed to get the downconversion to work. Most people don't have IMAQ, so you may end up waiting a while.
Member
GJAKLDFJG
So what do you suggest, what should I do. Can you help me with a solution, I need to have this vi in order to proceed further in my project.
Trusted Enthusiast
crossrulz
For anybody who wants to try to convert, you will need this installed.  Apparently, the IMAQ USB was made obsolete with LabVIEW 2009.  The capability was put into the IMAQdx drivers.
Here's where the original VI can be found.
Kudos always welcome for helpful posts...Kudos always welcome for any post.
Member
BramJ
Are there any image displays in the VI? Try removing those and put them back after conversion
I convert VI's from 7.1.1 to 2010 quite often I get that error if there are image displays in the VI
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
