NI Home
Cart Cart | Help
You are here:
Reply
Member
Yjkim
Down convert from LV9.0 to LV 8.6 and LV8.5 (neovi)
This is LV9.0 version about NeoVI,please help me to convert.
thank you
Knight of NI
Re: Down convert from LV9.0 to LV 8.6 and LV8.5 (neovi)
[ Edited ]
Tried to, but LabVIEW kept crashing when trying to downconvert. The code uses a DLL, and LabVIEW sometimes has problems downconverting VIs that use the Call Library Function Node. Maybe someone else might have better luck.
Otherwise, you can try uploading the DLL so the VIs can be relinked to it, and that might allow the downconversion to work.
Member
Yjkim
Re: up convert from LV5.1 to LV 8.6 and LV8.5
Then, this version can do the upconversion?
Member
Yjkim
Do you need this file?
neovi dll file
Knight of NI
I'm confused as to what you're asking for. Are you asking for a downconversion or an upconversion? And of which file?
Member
Yjkim
The files that I have
Is the 5.1 version and 9.0 version.
Using one of two
I want to convert to version 8.6.
Nlabv_neo.zip : 9.0 Version
oldlabv_neo.zip : 5.1 Version
Member
Yjkim
To perform a conversion the way of as you mentioned, uploading and down conversion way,
Is threre anything file that I should provide to you ?
Knight of NI
I upconverted the oldlabnew file.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
