NI Home
Cart Cart | Help
You are here:
Reply
Member
Schaefchen007
Accepted Solution
Conversion from LV 5.1.1 to LV 6 or higher
Can anyone convert this little VI from LV 5.1.1 to LV 6 or higher so I can open it with Labview 2011? Thanks a lot!
Knight of NI
RavensFan
Re: Conversion from LV 5.1.1 to LV 6 or higher
Didn't you request the same file here?
Please be patient until someone with an old enough version of LabVIEW sees it and can convert it.
Member
Schaefchen007
Sorry! I tried to delete the previous post, but it seems imposible. But I do not need a conversion to LV 2011, a conversion up to LV 6 or so is enough, so that the old post is wrong. Sorry for double posting!
Knight of NI
You did not need to create a new thread. Simply adding a new message to your old thread would have sufficed. Besides, it wasn't really necessary. It's known your final target is 2011, so you would have been provided a version that is either 2011, or a version that you can open with 2011. Like the attached, which is in 8.2.
There's a link to a typedef from another library that you did not include. You can probably just disconnect the typedef, or simply recreate it.
Member
Schaefchen007
Thanks a lot!
Member
Will Huntley
I'm trying to do the same thing. Could you help?
Knight of NI
Please re-read the Conversion-Board-Rules.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
