NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
JordanG
Conversion Board Rules!
1. Create a "New message"
2. In your post, please indicate:
Source LabVIEW version
Target LabVIEW Version
3. Mark the thread as solved on the message where you get the converted files. Select "Accept as Solution"
Please remember this is not a space for code discussion. This is just a space for you to post the VIs you need to be converted to an older or newer version of LabVIEW. If an issue arises where you need further assistance after the conversion has been completed (for instance, if you need the converted
VI to be removed from the forums) please select "Report to a Moderator."
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
