NI Home > Community > NI Discussion Forums
Version Conversion
Do you mean
Reply
Member
Accepted Solution
Clear Variant from LV5.0 to LV2011
Could someone take this ni code and upconvert to something LV2011 can open?  I want to see if it will help with my memory leak.
http://digital.ni.com/public.nsf/allkb/53D95658A17AFBF0862566110058842B
Knight of NI
Re: Clear Variant from LV5.0 to LV2011
attached
Member
Would it be possible for you to convert the same file to LV2010? I'm having a similar issue. Thanks.
Member
Here it is in 2010.  In the end my memory leak was the result of something else.
