NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
JeffC
"resman.exe -o -l" results in "NI VXI Resource Manager has stopped working" error.
When running "resman.exe -l -o" from a command line, I get the error "NI VXI Resource Manager has stopped working" pop-up.
It appears that resman has run since I can access the VXI instruments (i.e. via Soft Front Panels). However, I need to eliminate the pop-up.
Running NI-VXI 3.80 on Windows 7 32-bit.
Member
Jake_H
Re: "resman.exe -o -l" results in "NI VXI Resource Manager has stopped working" error.
Hi Jeff,
I ran the Resman -o -l command on a system running Windows 7 32 bit and VXI 3.8 (see attached pictures). I had an error the first time because I still had the logical address of the MXI card set to 0. After changing it to 1, I ran the Resman silently from a command line without problems. I was also able to run Resman from Measurement & Automation Explorer without errors along with running the Resman -o and Resman -l commands. Can you run Resman from Measurement & Automation Explorer or use any of the other commands without the pop-up error? Can you confirm that this command is only being sent once? Had you already run Resman at this point?
Jake H | Applications Engineer | National Instruments
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
